redneckfordf2502002
- May 18, 2012
- 1
- In the backwoods of AZ
- Ford
- Engine Size
- 2.8L V6 4.0L V6
Ok so the truck wasn't really struck by a tornado but sure looks like it was.
Recently we picked up a 96 ranger 2wd 4 banger stick shift green with tan interior (well what was left of the interior.
Problems with this truck: Has quite a few dents but nothing some body work can't take care of, the interior is gutted minus dash, carpet, and a few interior trim pieces along with door panels, windshield is broken, left window is missing, back window is missing, it is green, the 3rd gen body style is not the best looking in my opinion, the truck's engine is missing and probably more.
Good: it was $250 with a tittle and was the same wheel base as my chassis I have.
Now I know what you are thinking it is a 2wd 4 banger mine as well lower it and make a street rod out of it but oh no this baby is going through way more!
When I picked up my explorer it came with a parts truck 92 ranger 4x4 4.0L V6 A4LD auto transfer case with bad front hubs. The rest is good had close to $1200 put into it before he found out the tittle had a problem.
The explorer is my Daily driver so the ranger will be my brother (the one that gets the Bronco 2) daily driver and truck (yes he is a member and will probably update this thread once in a while but I will be doing most of the work (oldest brother always have to help the youngers) LOL)
So plan is this:
Phase 1:
swap the 96 body, clip, bed, and bumpers onto the 92 chassis once I figure out the small problem with the 4.0L. Find a set of hubs and use all the wiring from the 92. I know I will have a little custom wiring to do but using the 92 wiring, computer and all that will make it much easier. All interior minus door panels, rear jump seats, and headliner from the 92 will be going into the 96 cab. Probably will be using the A/c system from the 96 if possible.
Before I swap it I probably will pull a few of the dents out.
Unfortunately the 92 dash top does have cracking but I will be running it for a while.
Once it is running and driving start with cosmetics!
Either I will be fixing the front clip and hope the 3rd gen ranger grows on me or will be doing a different swap to something different. If I can I will use the 2nd gen front clip on it but only if the body lines take little to no work to match up (little things like that drive me nuts). If I can use the 2nd gen front clip it will make the front part of the truck even easier.
Find a left window glass and windshield (I have the rear window in good shape sliding rear which I have verified will fit.)
Find a set of 15" tires (probably 235 75 R15s) to fit the stock 92 ranger wheels that I have then will paint them black and put chrome caps on them.
That will be phase 1 my brother will just drive it like it is.
Phase 2 (fun modding begins):
once the 4.0L or A4LD lets go drop a 302 or 351 under the hood bolted to probably a C6 or AOD.
smoked or clear all lights (probably will just VHT the turns and tail lights along with third brake light)
Either way probably a billet grille weather I keep the 96 clip or go to the 92 clip.
CB radio with dual firesticks on the rear bumper probably.
Either a camper shell, roll bar, a tonna cover, or a truck box.
Brush guard.
Tons of lights.
Cowl hood (much later)
enough lift for 31s or 33s
regear to accomidate
nicer wheels
probably a lot more I can't think of right now.
here are the pics of what it looks like right now.
Trav
with the bronco 2, my F150, and my other brother's F250:
I did get the drop in bedliner out and the tailgate mounted:
So plan is this:
Phase 1:
Brush guard.
Tons of lights.
nicer wheels
Trav
