Tow hitch for off-road recovery/snatch straps
wildbill23c
577
Southwestern Idaho
215/70-R14
They do have a front winch/non winch bumper for the BII... and I can't imagine that the rear bumper couldn't be fitted with a set of new mounting brackets.
Hmm, what company are those bumpers on the Ranger from? The rear tire carrier doesn't attach to the bumper, only the rear quarter panel and rear hatch, 2 horrible mounting locations LOL. I haven't really found anything as of yet that would work. Wonder what a fab shop would charge to build something because that tire carrier is going to rip the rear hatch and quarter panel apart.
timmyflew
6
North Carolina
Ranger FX4
Minor T Bar Crank, Stock Rear
32x11.5x15
So did anyone end up finding information about a front hitch receiver. Curt advertises one but can't find much info on it. I am also wondering if one can be fabricated to use the connection points on my factory front recovery loops.
45657
JMF661
120
Montana
Ford Ranger XLT
Stock
31” x 10.5”
I ended up installing a Reese 65017 on the front of my 94. I removed the air dam piece for now. It fits pretty high and flush, doesn’t hang down or look too bad. I will post a picture once I’m back at the house.
Blmpkn
Toilet enthusiast
6,381
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
So did anyone end up finding information about a front hitch receiver. Curt advertises one but can't find much info on it. I am also wondering if one can be fabricated to use the connection points on my factory front recovery loops.View attachment 45657
If Curt advertises one for your truck and it's what your looking for id just get it. If it doesn't fit for whatever reason you'd get your money back and they'd probably even provide you with a return shipping label at their expense.
The lack of information on them im sure stems from the fact (assumption, really) that people who buy front receivers are 70 year old RV'ers that don't know how to internet.
As for getting one custom fabbed, nearly anything can be made to work with enough money.
timmyflew
6
North Carolina
Ranger FX4
32x11.5x15
Thanks for the replies so far. I had someone direct me to pictures of the one Curt offers and that will be a no go. The Curt one mounts pretty much under the bumper. It also appears it would not work with my factory skid plate. Just wanted to share that for anyone else wondering. Looks like fabrication is the best bet for me.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,789
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The only place that I know that sells one is etrailer. It night be the very one you are talking about though.
I’m holding out for an Affordable Off Road bumper instead.
timmyflew
6
North Carolina
Ranger FX4
32x11.5x15
Ordered the Affordable Offroad Bumper last night. Just finished taking off the bumper and the OEM stainless tow hooks. I'll post some pics and let everyone know how the AO bumper works out. I'm going to sell the tow hooks to get some money back.
4x4prepper
216
Atlanta
> just push the recovery strap loop in the receiver and put the largest diameter hardened bolt I can get though the receiver holes and strap loop.
Ditto.
I have never seen or know of anyone that has broken the 5/8" pin in a receiver when using an inserted strap.
Usually on the front and rear of my 4x4 I have 2" ball pintle hooks flat mounted (no receiver). Now, when I do tree work (same set up on my larger 4x4) I do not use the ball for the strap, rope, or cable. I use them to prevent the cable from being pulled off, the main stress is on the bottom of the cast iron pintle. I have broken sch 70/80? alloy transport chain using my 7600# 4x4, so, I kind of doubt the ball can easily be broken off using a Ranger/B2/Explorer. I think mine have 1 1/8" shanks.
If you put just tow hooks on the frame of the B2 you can easily bend and rip the flange, I have fixed that from people that did not know better. A receiver hitch front and back, backed up by plates (not just nuts and washers) is a great option. What I have done when using just hooks is run a tube right to left connecting them both, basically boxing the frame.
sgtsandman
12,789
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
The problem with using a ball is when people shock load them trying to pull someone out.
Just pulling with a steady load isn’t getting the job done. So they get a good run to get that extra jolt. That’s when ball hitches snap and become projectiles. That reason is why people just plain advise against using a ball hitch as a recovery point.
