Towing 1990 Broncoii
snoranger
Professional money waster
ASE Certified Tech
13,729
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
As said you could, BLOCK THE WHEELS, and remove shift motor, then manually turn shift rod to Neutral, vehicle will roll away so block the wheels FIRST
Where's your sense of adventure?!?!
rusty ol ranger
2.9 Mafia-Don
7,715
Michigan
177 CID
No, you can't flat tow it as is
There is a NEUTRAL on the electric shift transfer cases, there is just not a selection for it on the switch or in the 4x4 module that operates the shift motor
Look here: https://www.explorerforum.com/forums/index.php?threads/how-to-rebuild-4x4-shift-motor.123542/
4th picture down shows the transfer case gear selections, its in 2WD in the picture, 2H
Opposite 2H is NEUTRAL , between 4H and 4L, its unmarked but is there
You need to hold it in neutral so visegrip the rod and tie it off
In the long run you could add a neutral switch, the shift motor has internal contacts for the neutral position
So you could add a switch to move shift motor to neutral position and hold it there
Ford used to sell a kit for that, a Neutral switch kit
I wish ida known about pulling the shift motor back when i had my expedition....
Hit a deer and punched the oil filter open ford so smartly mounted right behind the friggin bumper.
Flat towed it 4 miles and ended up having to buy a trans.
alwaysFlOoReD
5,144
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Ouch.
rusty ol ranger
2.9 Mafia-Don
7,715
Michigan
177 CID
alwaysFlOoReD
5,144
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
