towing/hauling with a ranger. 4.0 or V8 5.0 conversion?
echo
FORD
I have an 88 4x4 with a 2.9l. Looking to get more towing and hauling out of it. I was wondering if I should source out a newer 4.0 that drops right in if I'm correct or go the step higher and covert to a 302 V8? Is the conversion worth all the extra work?
martin
26
St Bruno, Quebec
1991
It all depends on what you want to tow, and how often you want to do it.
8,372
Legally it won't change the towing capacity, so if there was an accident, doesn't have to be weight related or even your fault, your insurance company could just walk away, legally.
That being said gearing might be a better solution.
2.9l = 140hp
4.0l =160hp, 15% increase
5.0l = 210hp, 50% increase
5.0l might be less work, depending what fuel and ignition system you use
gw33gp
538
Costa Mesa, CA
4.0 SOHC
33"
You didn't list the torque which is very important when towing. The 2.9L engine put out 170 lb-ft peek torque and the 4.0L OHV engine put out 225 lb-ft peek torque. The 5.0 L is around 280 lb-ft peek torque.
The 5.0 still looks much better but the 4.0 is a very good improvement over the 2.9.
ronclark
25
Woodland, WA
95 4.0 with 93 ECU
One more key factor is were the peak torque.
The 4.0L is around 1800, the 5.0L is higher I can't remember off the top of my head.
I can tell you the 4.0L walkes over the 2.9L, when the the 2.9L is working hard the 4.0L is just getting warmed up.
My Ranger is a 4x4 4.0L 5 speed, 4:10 with 30's its down right scarry what it can tow. I can pull way more than I can posable stop with out trailer brakes.
Sent from my myTouch_4G_Slide using Tapatalk 2
