tranny help please
Hondafreak08
Dayton, ohio
2.9
So i have a 88 ford ranger 5sp 4wd (no idea what trans). For the last year i have really had to slow down to shift from 3rd to 2nd. Now it is hard to get into every gear. Like it wont come out of 1st or any gear with out moving it just right or forcing it. When i force it it grinds. Any help appreciated
Natedog
5
CA
How's the fluid look? Is it full? How manyh miles on it? Does double clutching help?
Hondafreak08
Dayton, ohio
2.9
been awhile since i checked fluid, so i cant safely say its perfect but i suspect it to be ok. Double clutching doesnt help. Today i drove it and it was fine but i didnt romp on it. I put a slave cylinder in it last winter so im sure thats fine
Natedog
5
CA
I'd check the fluid color and fill level for starters.
MAKG
19
California central coast
Check that the CLUTCH is releasing properly. Transmission problems in ALL gears are not terribly likely.
Will
TRS 25th Anniversary
514
Gnaw Bone, Indiana
Toyota
Make sure the firewall isn't tearing out where the slave is mounted. That happened on my '91.
Hondafreak08
Dayton, ohio
2.9
well it mostly happens between 1st and 2nd.. and only happens when its been drove 15+ minutes
Sdude2008
18
Farmington CT
3.0 Flex
31x10.5x15
My 88 5 speed shifts smoothly when cold but when it is hot it grinds 3rd-4th unless I pull 3rd, pause and then catch 4th... Any ideas?
Hondafreak08
Dayton, ohio
2.9
i changed the fluid and that seemed to fix it,, it doesnt want to shift when cold but then its fine,,, Now its noisy in neutral,, any idea?
