Trans or rear axle problem
Jspeed4x4
Roseville Ca.
I have a 1993 ranger splash 4.0 4x4 with a superlift 5 1/2" stage two lift kit and superlift steering kit. i have problem that every time i hit the gas hard it fills like the trans is hiting the under body of the truck. i have check the trans mount and even replaced it but did not fix the problem.what it fills like to me is that the axle is shifting a little forward when hard on the gas.truck has stock rear leafs and a add-a-leaf sitting on the stock block and i added a 3 inch block to level truck ride. I have check al bolts and hardware are tight. any help with this would be great. do i have to much drive staft angle. i'm worry that if i wheel to hard that something is going brake and leave me stranded
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Transmission mount on the crossmember. It's rubber and tend to rip.
Jspeed4x4
Roseville Ca.
Thats what i thought but when i put the new mount on there was nothing wrong with the old rubber still atached to the metal body. thats why i'm stumped on the problem i'm having.
Jspeed4x4
Roseville Ca.
Is it posible that the slip yoke is frozen or binding on the drive shaft. checked the slip yoke teeth are in good shape and there is grease on the both part of the slid teeth.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
I couldnt tell mine was broken until I completely removed it. (tranny mount)
4x4mike2004
6
Hazleton PA
4.squirill
from then description of the rear suspension, it sounds like a bad case of axle wrap. Best fix would be whole new leave springs, and a traction bar. if thats a little much a traction bar would help.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
My 4 banger 2wd did the same thing, turns out I had a bad motor mount...
SVT
Now let me get something clarified about the rear setup.
You have the stock springs with 1 added leaf, on top of the factory block, on top of ANOTHER 3" block, correct?
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Oh, shit. I didnt even notice he said that. Yup, that's axle wrap for sure. Get those damn stacked blocks out of there ASAP. It's dangerous and doesnt pass inpsection in most states.
Maybe one of these is more his speed:
He is from Cali after all.
Jspeed4x4
Roseville Ca.
hey now, More leafs less block got it. had a filling that maybe the problem just wasn't sure. thanks for the help
