Transfer Case Leak And Repair
sluhbmet
Maumelle, Arkansas
So I crawled under the ranger today to PB Blast some rusty exhaust bolts in preparation for removing the transmission to replace a bad slave cylinder this weekend. I wasn't under there very long before I saw, what I believe to be the rear transfer case output seal leaking. I have no idea how long this has been leaking (oil change guys never mentioned anything) but I went and picked up a new seal at O'Reilly's ($21-National) they suggested that I would probably need to by a sleeve that fits over the "yoke". They said the yoke probably has been chewed down a bit and just replacing the seal won't fix the leak now. I looked at the sleeve and understand how it works and it seems plausible that my output yoke could be chewed down a bit from rubbing on the wrong (metal) part of the worn out seal. Is it common to have to use the sleeve method to repair the leak. I don't know if it serves any purpose, but I'm gonna try to include a picture or two of my transfer case so you can see how much leaking I'm talking about. Hopefully the pic shows up. Thanks for any advice.
sluhbmet
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
only use a sleeve if you actually have to, you most likely will not need it.
just take a look to see if the seal is actually damaged or if it is just not holding oil anymore, its easy to change
F150hybred
Arborg Manitoba Canada
Um... Your seal could be leaking... but I'm wondering if the oil isn't possibly coming from the VSS seeing as there is no cable hooked up to it.
Earl43P
38
Farmington, Pa
Ford F250 4WD
You have no idea how long it has been leaking.
I'd drain out the fluid and measure how much drains out compared to how much it is supposed to hold. Based on that, you can gage the life likely left in it. Not much ATF = short potential lifespan.
I'd also grab that rear output shaft and wiggle it. If it has a lot of radial play, it is toast and the new seal/kit won't help (bad bearing from oil starvation).
If you find either of these conditions, I'd look around for a replacement transfer case. They are easy to find and can be had fairly cheap.
http://www.therangerstation.com/tech_library/TransCaseMaint.html
http://www.therangerstation.com/tech_library/TransferCases.html
Better? That's what I meant, but I sure didn't say it well....
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
I'd drain out the fluid and measure how much drains out compared to how much it is supposed to hold. I'd also grab that rear output shaft and wiggle it. If it has a lot of radial play, it is toast and the new seal/kit won't help (bad bearing from oil starvation).
Huh?
My motor has had an oil leak for about 100K. Should I replace it?
Things leak, if it's bad it's bad, but don't go out and buy a transfer case on the incase of the 1% chance it could be bad.
sluhbmet
Maumelle, Arkansas
Honestly, I had no idea that there was even a hint of a leak. I live in an apartment complex with asphalt driveways and hadn't noticed any fluid under the truck (excepts for a/c water drip on hot days). I can say for a fact that I will be looking for a good reputable oil change place in the Little Rock area in the immediate future (suggestions welcome). I dug out my past service records from the Exon/Mobil station and there was no mention of any leaks listed on them. There are no grinding noises or any other noises for that matter coming from the transfer case, so if a bearing is shot (due to oil starvation), it sure is a quiet one. I'll be topping it off with Mercon ATF tonight just to make sure no further damage occurs and the tranny is coming out this weekend anyways for a new slave cylinder, so I guess I'll wait to bend over and take it in the A*$ then. I checked the u-joints and drive shaft for damage, thought maybe it had a wobble or balance issue. I couldn't find anything (blatantly obvious) wrong with the driveshaft itself, but found the center support bearing to have plenty of slop in it (truck was still hot). I don't know how much play in that support bearing is normal. I can wiggle the driveshaft and that center support bearing/rubber moves probably 1/4 in. any direction. However, the rubber portion around the bearing appears to be intact, just seems maybe a little flimsy. However, it is hard to see completely though. Are those center support bearings hard to put on? As always, any advice is greatly appreciated and a huge thanks for everyones input already. Sorry for writing a novel...
sluhbmet
sluhbmet
Maumelle, Arkansas
Well that was fun... I just topped off my transfer case with mercon atf fluid. Good News--It didn't take hardly any fluid before it started running back out the fill hole (maybe a 16th of a quart, extremely minimal). So I'm keeping my fingers crossed that I'll only have to replace the rear output seal this weekend.
sluhbmet
rangerstzz
b.c. canada
2.3-2.9
x 2, sluhbmet, is your speedometer working?
Nailzs
salisbury, md. east of cheasapeake bay
4.0l
ummm, its an electric sensor, not a cable
if it was cable driven the speedo would show 0 all the time
as for the leak. its seepage mainly. not something to really worry about. and its so dirty its hard to tell where the leak is coming from. just check the fluid level every now and then and you should be fine
F150hybred
With the amount of dirt and crud packed around it, it's quite hard to tell. For the record, with it being that packed up with crap, it looks just like one that receives a cable. :annoyed:
sluhbmet
Maumelle, Arkansas
Yep, speedometer works perfectly. That is just the speed sensor up there and it only has a electrical plug attached to it. Believe it or not, that's just highway dirt and tranny fluid mixed together. The truck never see's off-road (mud). I'm gonna take it to the car wash tonight or tomorrow and clean it off. I have a can of engine degreaser that I want to spray liberally over the transfer case and let it set, before going to the car wash, but I gotta find a gravel parking lot to do that on. My apartment complex manager would kill me if I sprayed it on and let it drip off on the driveway, or she might raise my rent when lease renewal time comes around. Oh wait, they are already doing that... :icon_confused: Nailz, you bring up a good point. I hope it's not leaking around the speed sensor. Cause I just bought a rear output seal for nothing then.
Thanks for all the help and suggestions. Can't wait to tear into this thing over the weekend.
sluhbmet
Lilred99
Lafayette, TN
Ford Ranger XLT
im diagnosing the same light and wont shift into four low. Also gets stuck in four high then throws blinking code. Cleaned all contacts. Fixed bare spot on wire on TC pigtail to shift motor. Motor now shifts between all modes without error. Question is when I took motor off I lost a tablespoon of fluid. It appears to be coming from the keyhole. What’s seal is causing this leak and how hard is it to repair? Can it be done without taking TC down? Where to buy and diagram would be awesome as well
