Transfer case single knock
irishwolf
Victoria
Hi folks,
I'm new to the forum and this is my first post. Awesome to see an entire forum dedicated to rangers!
I’ve got a 2008 Sport 4x4 with a 4.0L manual with just under 200k km. Had it about 4 years. Love it. Everything is stock. Currently pulling the tranny to replace the clutch for its first time. When I pulled the transfer case I noticed a couple of things on the rear shaft output that I was hoping to get some feedback on:
1. Turning it feels/sounds rough, and
2. There’s a bit of a knock on first turn. Pretty sure I've heard this noise sometimes on first drive.
Curious if these sounds are normal or if I should be fixing something while I have it out?
I’ve since drained the fluid - it was very dirty and not overly viscus.
Any feedback is greatly appreciated!
Here's a video of the noises:
https://www.youtube.com/shorts/csAp3kkTZEI
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Welcome to TRS.
The knock noise is normal. I can't recall if it's part of the internal oil pump or part of the low range gear assy, but every t-case I've ever had out of a truck makes that noise.
However the roughness is not normal. Based on that I'd probably take a peek inside and see if anything is worn (bearings, oil pump, etc.).
I'll move this over to the Transfer Cases & Locking Hubs section.
irishwolf
Victoria
Welcome to TRS.
Cheers @4x4junkie, appreciate the response. I’ll have a look inside then and see what’s up.
