RangertoWork
- Jan 5, 2023
- 3
- California
- Ford Ranger
Hello,
2008 4c 2.3L automatic.
Getting P0715 code. checked the TSS sensor at the transmission plug and got 112ohm, so the sensor seems to be ok.
I want to check cabling at PCM, but I can't seem to find how the pins are numbered? is it 1 at the top left and just keep counting? or is in when your facing the PCM module?
Hopefully someone has a diagram of the connector that shows what pins are what number.
I have already looked at this diagram, but it's a little lacking in labeling. Are the conductor numbers on the left and right of the sheet the pins on the PCM module? Also, this is for the 4.0L, so i don't know if it's the same for the 2.3L
file:///D:/DOWNLOADS/1997%204.0%20engine%204-1.pdf
Thanks
Thanks
