transmission swap info
twoshoes028
i have a 1990 ranger with the 2.3L and a 5 speed tranny does any1 kno what tranny this is and if it is compatible with a 4.0L engine of the same year thanks
4x4RangerGuy
5
Newton Highlands, MA
Subaru
2.0
It should be the M5OD-R1 5 speed transmission, and I don't believe it is compatible with the 4.0 since they have different bellhousings.
MAKG
19
California central coast
They have different bolt patterns. M5ODs do not have separate bellhousings.
jwatembach
I think it is a M5OD-R1. I have found some sites that have the info, I will post them later. The M5OD is a weak, I mean WEAK tranny. I don't think it would hold up for long.
MAKG
19
Umm, M5ODs hold up fine behind even V8s (R2 was behind 5.0Ls) for hundreds of thousands of miles, though ZFs are preferred for that application. It can stand a 2.3L. Or even a 4.0L SOHC.
The only thing that makes them weak is driver error. Like not checking the oil level ever. But no transmission will last long at all with insufficient lubricant.
jwatembach
The one thing I do know is they can not take down shifting. Down shifting destroys the counter shaft bearings. I just tore through a rebuilt one is 30,000 miles. I did four months of research before I rebuilt it myself and everyone I talked to agreed that they are weak.
TireIron
Methuen, MA
I don't know how weak they really are... If you know how to shift it (like a truck, not a double or triple synchro'd sports car tranny) then it will last a good long time even with lots and lots of downshifting. Unless I'm just the exception to the rule getting hundreds of thousands of miles out of M5ODs.
MAKG
19
The early transmissions get a little "notchy" between 2nd and 3rd due to a design error (there is a TSB), but I've NEVER heard of an M5OD being done in in this manner. I would imagine you could do a lot of damage with "power shifts." Nearly all the complaints I've seen (including the "notchiness") could be explained by incorrect fluid or oil starvation.
My own has 235K miles, and I downshift ALL the time, including with heavy deceleration (above 4000 RPM). It's an essential and very frequently used skill for mountain drivers.
I guess a lot of people don't shift very well. Further evidence is complaints of clutch lifetime. Mine always seem to last around 150K miles.
