Transverse Leaf?
dannyboy3141
I have been contemplating a transverse leaf rear end on my Ranger and was wondering what thoughts or advice you guys had. How should I go about it? What should I do or not do? Any considerations? Would I be able to do this with the Ford 8.8 independent rear axle from an explorer? Should I go Dana 44 instead? Thoughts please.
I wasn't sure whether to post this here (because it may take some fabrication) or in the Mini-Truck section, so you can find an identical post there as well.
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I've decided to leave this here and delete the other one.
I believe corvettes had a transverse leaf independent rear setup, you might want to check there for ideas. Also I think gwaii had a transverse setup but I can't remember which thread and if it was front or rear axle.
Rex2nr
Rochester, NY
Vettes did have a transverse leaf. I'm not sure what years, but it seems up through at least the c4
dannyboy3141
Basically I am looking for a form of Independent rear that I can do with leaf springs. If you guys have any ideas for anything a little stiffer than transverse, let me know.
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Assuming the pumpkin mounted solid;
Cut the leaf in half and mount solid to the frame with links to control outer.
Use two half leaves mounted above and below frame. -gets rid of links.
By the way, neither of these is my original idea but is stuff I've run across on the web. Sorry, I have no links or know how well these ideas worked.
