AgPete139
09/2014 OTOTM Winner
- Aug 12, 2007
- 61
- Houston, TX
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L OHV
- 2WD / 4WD
- Solid Axle Swap 4x4
- Total Lift
- ~9"
- Tire Size
- 35"x12.50"x17"
Alex & Craig, your hats have been Fedex'd and in transit. You should be receiving them in the next couple of days. They were shipped on Tuesday, February 7th.
Nitro, the hat should fit, and you would be at the upper limit of the medium. Everyone's heads are shaped differently. Some have said its perfect, while there have been a couple complaints that they are on the "shallow side." Do you think you have an longer (watermelon(?)) or taller head? It's elastic and cotton, so it can stretch and conform a little bit. I would gues "yes" it will fit you.Mine is a 7 1/8th. Good on the medium or not??
Dieseldane, if this is the case, then it will probably not fit you. However, I have sent you a PM. Check your Inbox.Just went and measured myself. 23 1/4 in, or 59 cm. That make me a medium according to your sizes? The hat I'm wearing now says XL, and it was kinda tight when I first got it...
I finally have 2 medium black hats left. Are you interested?Got any hats left?
