truck suddenly started running like crap
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
93 ranger 4.0l standard. Suddenly started running like crap on a traffic circle. Pulled over and let sit while I looked for anything obvious. Found nothing and have no tools with me....I just took them out this morning....go figure.
So if I let it sit for a minute it will fire up and run fine for about 30 seconds then starts crapping out again and eventually dies. Rinse and repeat.
Any ideas?
saskbill
6
Saskatoon, SK CANADA
Running like carp - sounds fishy! :icon_rofl:
Temporary crappiness gets better when you sit for a few minutes:
- fuel cap breather plugged?
- how long since your last fuel filter change?
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Loosened fuel cap, no difference. Not sure about filter but Schrader valve spits fuel onto the fender so lots of pressure. Its 38celcius maybe too hot?
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Rad fluid is good.
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Disconnecting IAC did nothing. Don't see any loose wires. The crank position sender wire has some exposed foil near the engine water outlet.
ericbphoto
Overlander in development
16,659
Wellford, SC
6"
No CEL? No codes? What about a vacuum issue?
This message composed solely of recycled electrons. Go green!
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
No tools. I towed it home and will look at it in the morning.
Oxygen sensor can do that. It is ignored for at least the first 30 seconds or so after startup.
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Thanks for the heads up.
I had one doing exactly what you describe a few years back. Never could figure it out until one night I am flying down the highway, had about 75 miles until I could get home, running stupid, and then BANG! it backfired and blew the cat shell open.
When I got down under it to fix the exhaust I found the O2 sensor was broken in two, and I suspect that was the root cause of all the problems.
ericbphoto
16,659
Wellford, SC
6"
I do believe that sudden noise would cause a mess in my pants. :annoyed:
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Once upon a time in small town canada, before there was cats on vehicles, we used to cruise down the main drag. When we saw a unsuspecting prospect we would shut the ignition off for a few seconds and when directly beside the person turn the ignition back on. Boy it was fun for just turned pubescent almost adult hi-jinks....
Until I had to replace a muffler. That cost me money and I stopped doing it.
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
adsm08; good call. The codes came back as o2 sensors, 172 and 176. I'll change them out hopefully tonight.
1990RangerinSK
1,312
Saskatchewan, Canada
My 85 did that. It'd been backfiring for a few days. Suddenly, I let off the gas to stop for a light, and BANG. When the light turned green, it was louder, so I pulled over and looked underneath. My brand new muffler was split right down the seam! I called and asked about warranty, telling them truthfully what had happened. Nope, no warranty.
Pfft, I knew a guy who did that in his early 40s.
That is pretty much how it happened to me. It went bang when I let off the gas to shift.
