Truck surges at startup when cold
Wayne6197
4
Mississippi
Hi. My 2000 Ranger revs up to around 2500 on cold mornings on startup. This lasts 10-15 minutes. Then it surges up to 2500, then back to 1500 or so every 3-4 seconds and will continue this until driven. I changed out the air control sensor, no vacuum leaks and thermostat is good per my mechanic. Any suggestions? Thank you.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
It sure sounds like a vacuum leak...
What engine is it?
Wayne6197
4
Mississippi
Hi. It is the 3.0L flex fuel.
Wayne6197
4
Mississippi
It does not do it unless it is below 50-60 degrees or so.
rubydist
858
Denver
Ford Ranger FX4
The other alternative is a sticky iac. If you cannot find a vacuum leak, I would change the iac.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Just an FYI...
I moved this to the 3.0L forum.
bills4065
Canada Military - Veteran
9
Dartmouth Nova Scotia Canada
It sounds like it is temperature related. You say your mechanic said your thermostat is fine.
Does your truck take a long time to warm up? A coolant temp sensor is a thermistor. One starting to fail can cause some some weird stuff.
Wayne6197
4
Mississippi
Thank you. I told him I thought it could be that but I guess he ignored me. Lol. Anyway I will change it and see. Thanks again.
Wayne6197
4
Mississippi
I changed it but nothing. Thank you though.
bills4065
9
I am talking about the temp sensor itself, not the thermostat. I am not clear on your answer, does the truck seem to take a long time to warm up?
Wayne6197
4
Mississippi
Yes, I am talking about the coolant temp sensor. I noticed one of the wires was off of the connector harness so I ordered it and the sensor today. The truck seems to warm up ok, it just does that weird surging after a while then if I try to drive it before it stops that it is almost impossible to shift. I am hoping the temp sensor and connector solve this. If not then I'll try the MAF sensor. Thank you.
gw33gp
536
Costa Mesa, CA
4.0 SOHC
33"
How old is the PCV valve? I had symptoms not exactly like yours but indicative of a vacuum leak. I changed the PCV valve, and the problem was solved.
Wayne6197
4
Mississippi
Probably the original one on the truck. So 24 years. Thank you. I'll check this out.
