Truck took a dump HELp
Hondafreak08
Dayton, ohio
So todat I was just playing behind the house and drove through some standing mud/ water. Well as i left the puddle the motor died. When i turn the key to ON. I cant hear the fuel pump turn on like i did before. Also the electric fan i rigged up doesnt work now. Is there any fuse or box that i should check. please help. i have trully no idea/
BobR
okanogan
ferd
inertia switch?
Bob
Hondafreak08
Dayton, ohio
where the inertia switch located?
Mutant Pony
9
Hersey, Mi
2300
You probably just got the ignition wet. Possibly sucked some water in the air cleaner. After it dries out a little it should be fine.
IMenriched
4
NE Iowa John Deere country
02'
2.9 & 5.4
It "Usually" is located inside the cab, just under the heater. or about where your left foot would be on the passanger side. is for my 86 anyway. for more info on this item check out the tech library here...
yeap ya might have just gotten her a bit wet too.... dry it out and try again.
If no luck....make sure your in nuetral..set brake... key on, do NOT start... open hood...unplug your map sensor, or take 1 of the battery clamps off the post...& put it back on ...every time you remake the connection you should be able to hear the pump repressurize....if you dont then you don't have power to the fuel pump.
hope that helps
Hondafreak08
Dayton, ohio
So i still cant figure it out. The injectors are not pulsing and the engine isnt getting spark. Is there another fuse box other than the one directly below the steering wheel? Any help needed
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
tfi module unplugged? bad? they control pump and spark
Psychopete
29
FW, IN
Check for a voltage reference on a sensor, eg. the TPS. I wonder if you blew a fuse link to the ECC relay? Check for +12v at the yellow wire @ pin-1 on the 60 pin ECC-IV harness and work your way from there... A wiring diagram would be most helpful, you might get by using a Chiltons if you keep in mind that it's not always exact. Vehicle specific Helm Inc. diagrams have been a life saver for me.
Looking at this diagram:
http://www.autozone.com/images/cds/gif/large/0900823d800f947b.gif
it shows that pin-1 is contantly getting powered, if you're not getting power here, your fuse link is smoked. If it's okay, move on to the ECC relay. As you can see, the injectors, sensors, fuel pump relay, etc. are getting powered on from this point. They physically all meet in one place as show in the diagram, on my 88, that point is in the mainharness, just after it gets through the firewall.
Pete
Edit:
Also, I don't know why your fan would quit, please explain how it's hooked up...
If the wiring diagram isn't making much sense, just keep at it. I've looked at these diagrams over a dozen times, so I can read them fairly quickly.
Hondafreak08
Dayton, ohio
so its not getting power on pin 1 so i guess i just make my way back and check the fusable links. Will this be my only problem?
Natedog
5
CA
Yes and not necessarily. Fix this problem first and then see how it runs.
Hondafreak08
Dayton, ohio
Fixed. Fusable link between pin #1 and battery. Next to sylinoid
