USAFJack
- Nov 24, 2020
- 4
- Washington USA
- Ford/Ranger
Hey y'all,
Got a 2004 Ranger XLT automatic and I can't get it to shift into 4Lo. YES, I have been doing it the correct way. Foot on brake in neutral but the solenoid never clicks over. The lights turn on normally for Lo and Hi when starting the truck and no issues with switching into 4Hi. I've swapped known good parts from a donor truck: 4x4 control module, shift motor, and a new transmission speed sensor. Checked all 4x4 related fuses and no breaks in fuses. Checked voltage on switch and that seems good. I've manually turned the keyway in the transfer case with the shift motor off and it engages in 4Lo that way so transfer case is good. What am I missing!?
