bigdan002001
- Oct 7, 2009
- 0
- Pandora, OH
- Ford
- Engine Size
- 4.0L
Hey guys, I have a 97 Ranger 4x4 with 4.0L OHV. I just pulled old motor and bought a used engine that looks almost brand new. Paint on block and everything looks pristine. Guy I bought it from said was pulled from a 97 Explorer with 90,000 miles but looked to him as if it were a replacment engine due to the cleanliness of the engine. Anyways, I finally got everything installed in my truck and now I have a clanking/knocking sound from the engine bay. Kinda sounds like a diesel at times, but almost sounds like something hitting something inside either bell housing or oil pan?? The motor was originally fitted for auto trans, and I bought and installed brand new flywheel, pressure plate, and LUK clutch set. Has brand new LUK slave as well. I used blue locktite on pressure plate bolts and torqued to spec. Truck runs great and has lots of power. Oil pressure is great as well. All the accessories on the front of engine are new as well....new power steering pump, new alternator, new a/c compressor, new idler pulley, and new tensioner. The only thing I did notice is that the harmonic balancer has a little damaged place on the edge/face of pulley. The pulley doesn't wobble or anything, but wondered if that might have something to do with noise? I thought about replacing with the one off my old engine, but wasn't sure if I could reuse damper bolt or not in center? Anyone have any ideas....
Thanks,
Dan
Thanks,
Dan
