twin stick conversion for 1354e
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The single shifter kit looks like It could work with my 2011. With how the console is setup around my manual transmission shifter, I can't see how I would be able to get the twin shifter to fit. At least not without loosing the only cup holders I have in order to do it.
Revtach
6
New York
Probably not worth it for the twin shifter anyway. The only added gear option it gives you is 2 low. Can you think of a situation where you would need 2 low? I can't. I'd get the less complicated, cheaper, and easier to install single shifter kit and be done with it.
sgtsandman
12,651
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I can't think of a definite one for 2 Low. Dragging logs or something like that? Tight turns on a trail where 2 High isn't enough but you don't want the scrub and bind of the front wheels locked in. Purely speculation on my part.
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
I use 2 low around home. I just like the slow speed control when driving around our property. Of course I just do it with the transfer case in 4 low and the front hubs unlocked.
17,838
SW Iowa
2lo probably means more for manual trucks.
I have used it quite a bit in mine already, it is a nice speed for crawling around the farm.
6gun
11
Calhoun,GA
Solid Axle Swap 4x4
39X12.50R17
I'm not afraid of dying, not living terrifies me!
I use Lo with the front hubs unlocked often simply for speed control/extra torque when riding back roads. Often on steep gravel FS roads and such. More because I'm often too lazy to get out and lock the hubs when 4X isn't needed. Not sure if I will ever go the doubler route but easily having access to low range is important to me.
