Uh oh? Part on drain plug magnet.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I just grabbed this from @Shran
That pin that the tensioner foot pivots.
You would have to think there would be other junk in the oil pan though.
Strange!
DRanger024
482
Dale, WI
Solid Axle Swap 4x4
6-7” front maybe 3” rear
33x12.50-15
I don’t have a broken tensioner and not really willing to break this one, sorry. I did, however grab some measurements off of it.
Guide is completely plastic so that probably isn’t it.
the pivot pin would be my guess. Looks to be aluminum. The “head” measures approximately 5/16” or 0.31
Small side. I’m guessing this would actually measure 0.25 or 1/4” but there’s a pretty good dimple to expand it.
other piece (pressure relief?) measures 0.375 or 3/8” on the smaller diameter.
DRanger024
482
Dale, WI
Solid Axle Swap 4x4
33x12.50-15
I don’t see anything related on the oil pump, baffle, oil pan/windage tray or the timing cover.
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
I'd take the timing cover off and check the tensioner becuase I'd kick my own butt if I didn't and it came apart and tore things up.
gaz
657
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
How could any part of the tensioner make its way inside the engine?
DRanger024
482
Dale, WI
Solid Axle Swap 4x4
33x12.50-15
See Uncle Gumps post above with the photo of Shrans engine.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
That seems likely
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
@richard booth
Did you come to a conclusion on what the mystery part is?
richard booth
28
Tacoma wa
2.9 for now.
@richard booth
No, I have not. Just running fine so going with something that flew into the motor during the build. Thanks a LOT for taking the time to measure all the parts for me. I looked at and measured a tensioner I had and no matching part. Maybe the oil level sensor came apart? But no other anything in the oil I screened. Appreciate your time and consideration, it runs great w good oil pressure.
richard booth
28
Tacoma wa
2.9 for now.
Thank you!
DRanger024
482
Dale, WI
Solid Axle Swap 4x4
33x12.50-15
No members online now.
