Updating the 2.8L Tech Page - Suggestions Needed
tidmarshsmiths5
South Carolina
2.8l stock
Suggestions:
Pictures of engine, transmission, transfer cases, wiring diagram big enough to read, pictures, carb pictures, smog emission sensors and what they do (pictures)...I'm a visual learner.
Would love to see a Chilton's manual downloaded on here for folks to reference.
Pictures of: valve cover replacment, water pump replacement how to, brake jobs, carb rebuild, parking brake adjustment, 4x4 grease and fill up points, auto vs free hubs, rear hatch fixes...basically a manual of sorts for the beginner.
Pros and cons for 2.8...I like the little engine that can, but I will probably have this one rebuilt one day or buy a 2.9 if it bolts right up to my Mitsubishi FM 145.
Door jam codes listed and what transmissions, rear ends, etc that were offered for 1985s and what each represents.
Cheap hp tricks (think someone mentioned this) and what bigger tires do in relative terms (for dummies like me) to torque, hp and tow ratings (since we can't get 195/75/15s hardly anymore).
wildbill23c
577
Southwestern Idaho
215/70-R14
The Duraspark update that everyone is mentioning would be great. I'm not very good with trying to do things like this, I've never done it before, I know what the parts are, but a good write up with good detailed pictures of the connections, and all the part numbers used would be nice. I plan on doing the swap, but I'm afraid to do too much not really knowing what connections go where, not to mention what vehicle I need to search for to get the right carburetor for the swap. I'm on a very tight budget so I need to know what I need not what "Might" work I can't afford to be buying parts that won't work. I can turn a wrench but when it comes to electronics and electrical on vehicles I try to avoid it.
As for the tire issue, my 84 Ford Bronco 2 came with 235/75-15 Tires, but I plan on putting close to the right size tires on it which I believe are 205/75-15 tires.
Another thing on the 2.8L section it would definitely be nice to have an engine view with all the main items pointed out as there are a lot of people here who don't know some of the stuff on these and my Haynes manual is garbage when it comes to this particular engine.
I've noticed too that a lot of questions relating to the 2.8L engine, the answer is swapping engines, well not everyone is rich enough to do so or equipped with a shop full of tools to do so. I would like to see the 2.8L engine section deal with this engine keep the engine swap stuff in a separate section. Not everyone wants to be changing their engines out, me for one see absolutely nothing wrong with the 2.8L V6, I've had 2 vehicles a ford ranger and now the ford bronco 2 with this engine and it is very under-rated on here by many people. Keep the nonsense engine swap ideas out of this section as the people coming to this section are wanting answers to this engine not about swapping to a different engine opening a whole new box full of problems.
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
i will be doing the tbi so ill take many pics, dont do good write ups but hey pics are worth alot. cooling upgrades like swapping the water pump pulley for a smaller one
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
very true as do i
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
kimcrwbr1
46
maplevalley WA
2.8l
komoto123
Kentucky
2.8 v6
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
fastpakr
2,845
Roanoke, VA
Leadchunker
Lawrenceville, GA
2.8
Duraspark conversion
This is always a topic of discussion with the 2.8l I know it is covered extensively on another thread.
JoshT
1,823
Macon/Fort Valley, GA
What about the Duraspark Conversion? There's already a tech article under the ignition section and a link to it in the main 2.8L tech article.
marana az
2.8 v6
What about a write up of mechanical fuel pump vs aftermarket electric fuel pump and how to install electric fuel pump ?
