Upper control arms for a 2002 Ford ranger XL
TheYellowRanger
6 inches
33 inches
Hey guys, I was wondering if anyone knew where I could get some control arms with inner changeable u joints. My Ranger has a 6 inch lift on the frontWith torsion bar suspension, And I have to change the upper control arms about once a year because those ball joints go out. Do y’all know if there’s a control arm with interchangeable ball joints like the lowers that I can use so I don’t have to change the whole control arm every time?
pjtoledo
2,988
Toledo Ohio
Fords
3.0 2.3
I would go to Rockauto and check out the specs & descriptions on the control arms. they will list lots of choices.
from that you get a brand & part number that matches your needs, then buy it at your preferred source.
Vindictus
330
NewBrunswick Canada
ReMan 4.0 SOHC
I know Moog make control arms with replaceable ball joints and I'm sure there are other makes. From what i've seen cheap one can't and more expensive ones you can
