Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
What are you doing when trying to shift it into 4 low?I have been lurking around the forum for over a month trying to shift into 4low, it shifts into 4 high but not low, could the sensor plate on the shift motor be bad and still shift to 4high? I have replaced everything else, the brake switch, the speed sensor on transmission, the control module, I assumed that since it shifted to 4high that meant my shift motor was ok, but now I am wondering, did i miss something, I can’t think of what else to waste money on?
4 low with a manual transmission, you need to be at a full stop with the clutch in or it won't shift. That is for going into and out of 4 low. It also shifts slower than going into and out of 4 high. It takes a little over a second to switch in and out. If it still doesn't shift, I would start looking at the wires and see if anything is damaged. Since it shifts in and out of 4 high, I can't see the motor being bad. Though there might be an issue with the contacts being dirty and maybe needing cleaned.I have been lurking around the forum for over a month trying to shift into 4low, it shifts into 4 high but not low, could the sensor plate on the shift motor be bad and still shift to 4high? I have replaced everything else, the brake switch, the speed sensor on transmission, the control module, I assumed that since it shifted to 4high that meant my shift motor was ok, but now I am wondering, did i miss something, I can’t think of what else to waste money on?
