V8 Motor Mounts
Hjcraver
MRE BOOKS WROTE : Motor mounts are simple to build for this swap. Ranger motor mounts consist of a rubber pad with a stud sticking out of each side. One stud goes through the frame and has a nut which screws on the back to attach it to the frame. The other stud sticks straight up and attachés to a
motor bracket. Four cylinder motor mounts are usually hydraulically filled and are weaker than the V6 mounts, which are a solid rubber mount. Whenever possible, use the V6 mounts. These are used on 3.0L and 4.0L Rangers.
Fabricate two new brackets from 1/4-inch plate steel to bolt onto the side of the V8 motor at the motor mount bosses. This isn't as difficult as it
might sound. These brackets are just pieces of 1/4 inch steel with two holesdrilled through them so that they can bolt to the block, and then two more holes, one for the motor mount stud, the other for the alignment pin which also sticks up rom the motor mount.
The stock 4.0 Motor Mounts from WESTAR #2641 and # 2642 are only about $40.00 for the set. Being a Metal fabricator I can easily build the steel mounting plate. It looks to me like this may position the engine a little high.
Does anyone have any experience in using this method and how did it work?
projectnitemare
8
Osceola Mills, Pa
396W
They are a piece of cake to build. Look the the TRS tech articles there will be a template, it is the exact same type of mount I built. The 2.9, 3.0 and 4.0 are all the same lower mount. You will have to move that mount around on the crossmember for final placement. If you leave them in the stock holes it will be quite high, move them down and drill new holes. My oil pan is about 1/8 in from the TTB crossmember. They work pretty well for the little investment. You can get them at the junkyard if you want on the cheap or buy new.
Matt
v-8power
31
Huntington, In.
Hubert,
I would set the motor as low and far back as i could if i were you.
I take it you recieved that tranny ok?
Hjcraver
Brian, The Tranny worked great. Thanks. The picture of your 351W Headers in another Post is Super. Did you buy them or fabricate them?
v-8power
31
Huntington, In.
Those i bought from total performance. I am glad the tranny worked for ya.
bottledgt
im ny opinion this doesnt work so well for some. i used this on my last ranger with v6 mounts. my motor had a fairly lopey cam and at idle the motor bounced all over the place. probably not bad on a real small cammed motor thouhg
V8 power...do you have a link to a site for those headers? im looking for something to put on my 331 soon. the crap shortys i have are about gone
projectnitemare
8
Osceola Mills, Pa
396W
I have a very radical cam and use these mounts without any problems. A lot of it depends on placement. The lower in the frame the better because this will make the steel plate smaller creating less leverage to rock the engine around. If you are still concerned with high torque, build a torque link to keep the engine from twisting on the rubber mounts.
Matt
v-8power
31
Huntington, In.
Sorry they don't have a website. i can get you their phone number and email if you would like.
Drg racr
Southern Michigan
Post the phone # or web address. I'm in the planning stages of my 351W Ranger project.
Hjcraver
Hjcraver
Brian, I havent talked to them yet. Still saving my pennys and doing some more research. Just trying to finish wiring my shop and hopefully reverse my cash flow. I am actually looking for a 93-95 Step-Side, my 93 is a Straight side.
Check out this guys mounts selling on Ebay, 1988 FORD RANGER V-8 SWAP MOTOR MOUNTS Item number: 220188820097
