Blossomforth
- Feb 11, 2014
- 0
- CT
- Ford
I have a '96 2wd truck, manual trans, no a/c. Im replacing the vac lines that go to the EGR system, and i noticed i had a broken line coming off the plastic vacuum tank under the air intake tube. It doesnt seem to go anywhere, nor did i find any fittings/t's on the old plastic red/green lines that i removed. The other line on the tank goes under heater box into the firewall.
Can i T into my new egr vac lines? do i need to install a check valve before the tank? if so, which way does it face?
thank you for the help!
