Vibration while acceleration low speed
Gary101386
Oswego IL
I am getting a weird vibration in the truck at low speeds...
It's from a dead stop, accelerating to 15 mph...
I've checked stupid things like motor mounts, trans mounts, ball joints, tie rod's, and I can't seem to find it...
I don't feel of the steering, stick shift transmission it's just accelerating from 0 to 15 mph.
My truck is a 1989 Ranger 2.9L 4 x 4 with a 6 inch BDS lift and 33 inch tires. It is a manual transmission, manual transfer case. It has the 4.0 flywheel clutch conversion.
The lift, 4.0 clutch conversation were all done 2 years ago and haven't had issues till now.
Any help is most appreciated!
Gary101386
Oswego IL
I have also tried it from a 2nd gear start and no difference.
Gary101386
Oswego IL
I also had wheels rebalanced.
black_demon69
142
AZ
4.0l
u joints possibly
Dangerrangers
Ohio
94 and 04
4.0 s
Do it right the first time !!!!!!!!!!
Do you have a center carrier bearing on your rear drive shaft and if so get under the truck and push the shaft up and sideways and if it moves around then you need a new carrier bearing or ujoint .
Gary101386
Oswego IL
Yes I do and I just replaced that last year.
alwaysFlOoReD
5,173
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Check wheel bearings? Out of round tire? Spin tires and look to see if there is side to side movement? While spinning tire chalk a line down the center, that will help you see any deviations. Does the vibration coincide with engine rpm?
Gary101386
Oswego IL
Wheel bearings sound good. Haven't checked any wobble.
Vibration does not follow a specific rpm. It's a speed. 0-15mph.
3,614
What are your u-joint operating angles?
