Wanna help diagnose a crank no start? You know you do...
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Truck 89 BII.
Whats up:
- I rebuilt upper end of a used motor.
- Wiring harness worked fine with last motor, but old motor was overheated
- Cranks fine, but does not attempt start, no back firing, just hear pistons moving air and normal starting sounds
- I have 40psi at the fuel rail
- I have spark, but the spark is orange not blue
- I tried starter fluid in the throttle body, but no difference
- Pretty sure I am good with initial timing, and plug wires (new dist cap, roter and wires btw)
What do I look at next?
Any help appreciated.
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
WOuldnt I have no spark with a TFI problem?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
TFI module...
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
I have another distibutor on the shelf. Does it make sense to swap it out and see or should I do more diagnostics?
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
No need to pull the whole distributor.
Just get the 5 dollar TFI tool and swap TFI's between the two.
Heat eats the modules. If you overheated it and now you got this, itd be my #1 suspect.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Yeah, but I can swap the distrib out in 5 min. The TFI module is the plastic plug deal on the back right?
8,370
Ether(starting fluid) has a much lower ignition point than gasoline, which is why its a good starting fluid :)
So it would/should at least fire if there is even a weak spark at the right time
So my guess would be distributor is 180deg off, assuming you used the crank pully's timing mark, so rotor is pointed at #5 when #1 cylinder is on compression stroke
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Just went out with the other distributor, found TDC, redid the wires and nothing, same condition. I suppose its possible that both TFIs are bad, but I had one working in the last engine.
I found TDC by holding my finger over spark plug hole #1 and having someone bump it.When it blew my finger out, I figure that is compression. The harmonic balancer was pointing to TC. Then I lined the cap up with the rotor and called that terminal spark plug one and put the wires on according to the book in a clockwise order.
Did I do it right?
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
thanks for the help BTW you guys are freekin great
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
OK....after I installed the new distro I forgot to plug it in LMFAO!!! She fired right up!!! She smoked pretty good, but is running clean now
8,370
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
So for those looking to this thread in the future, I do believe it was the TFI, as I did have the timing correct of the first distributor I used.
Thanks guys!
