Elmobile
- Aug 7, 2008
- 0
- Age
- 34
- Ford
- Engine Size
- 4.0 Liter V6
************************WARNING***************************
I recently installed a superchips flashpaq tuner to increase fuel economy and correct my speedometer. The tuner was used on a 2008 Ford Ranger XLT 4x4 Supercab. I have the 4.0L V6 with automatic transmission.
The tuner tripped the anti theft system. The vehicle thought is was stolen and deactivated the starter. Somehow it caused a voltage increase to the fuel pump and managed to short it out. This in turn caused the engine to shut down completely and a complete loss of power steering occured while driving 65 mph on the highway while in the middle of going through a curve. Luckily it is was a desolate part of a rural highway so I managed to control the vehicle and roll to a somewhat save stop in the grass that seperates the two sides.
The ECM read back two DTCs once I was at the Ford Dealership. One code was P1260 (Theft Detected). The other code was P0232 (Fuel Pump Relay Force Fail Off). For some strange reason everytime I hit the brake pedal, the left turn signal came on. Another strange occurance was that even though my emergency lights were on as indicated on the dash, they were not actually flashing. Everything else still worked including the radio, ac, door locks, windows. Just wouldn't start and the dash kept flashing a lot of trouble lights.
Also once I uninstalled the tuner file and cleared all DTCs using the tuner, the vehicle returned back to normal and started back up. It has been running normally every since. The Ford Technicians could not find anything wrong with the vehicle. I had already uninstalled the tuner file and figured out the issue before the technicians had a chance to look at it. No parts have been replaced including a fuel pump or anykind of wiring. I suspect the sudden anti-theft trigger caused a voltage imbalance which probably triggered somekind of fuel pump safety switch.
So, this is a fair warning to those who use these tuners. There is a posibility that your vehicle can die on you at the most random times. I suspect this is probably a bigger problem for certain year models that have ECMs that can indicate theft detected. In all fairness to the situation, everytime the tuner was plugged in (only for using the performance monitoring log) it always triggered theft detected and all I had to do was clear the DTC and nothing bad happened.
