Weird Anomaly last friday coming home
4x4prepper
216
Atlanta
What you describe sounds like what happens when the valve (that looks like a fuel filter canister) near the tank goes bad, it acts like a fuel reservoir in case your fuel pump sucks air on an almost empty tank, as far as I can tell.
As someone noted, if you tank is over 1/4 full, it is not a problem. When I installed a 2.8L into a 1976 Alfa Romeo, I had to do a bunch of things to get the fuel system correct including installing an electric fuel pump to prime the mechanical pump and to install a Spider-Trax roll over valve on the return/vapor line. I had thought about reservoirs and such, but, not really needed because the tank pickup sat recessed.
groovtubin
29
NC
Ford Bronco II
What ULTIMATELY fixed it WHO KNOWS.. gotta friend who owns a Menieke shop, had it TOWED there ( died for good in town) they changed ALL ignition parts sans computer lol, OEM plugs, wires, distributor, cleaned injectors ( HUGE improvement) After ALL this it STIL had a MISS, hobbled home, n ordered (2) TFI modules, and a McCully Racing TFI RELOCATION Kit , n PROBLEM solved.. The BLACK module from Advance was bad,,,,, Runs like NEW at moment :) Thx 2 everyone for chiming in! :)
