Weird lever
lil_Blue_Ford
6,211
Butler, PA, USSA
4.9L
Both of my 89 Bronco IIs had that. Pretty sure my 92 Ranger has it. I’ll have to check the other stuff around here
scotts90ranger
4,445
Dayton Oregon
2.3 Turbo
Ok, so it's sounding like it either changed with the wiring change in mid '92 or with the body style change in '93, odd...
DRanger024
Ham Radio Operator
487
Dale, WI
Solid Axle Swap 4x4
6-7” front maybe 3” rear
33x12.50-15
Was there a mid year change in ‘92? I’ve never seen it in a ‘93 either. Maybe Ford ran out of parts for that style fuse panel before ‘93 and already had the new dash design for ‘95 in the works.
RobbieD
2.9l Mafia
3,553
Georgia
My best guess is the fuse box changed when the ECM moved.
scotts90ranger
4,445
Dayton Oregon
2.3 Turbo
They changed the cluster in mid '92 to a different color circuit board and is pinned differently so if you convert to a tach cluster you need one from the right version and apparently a lot of the dash wiring is different in that split color wise at least...
DRanger024
Ham Radio Operator
487
Dale, WI
Solid Axle Swap 4x4
33x12.50-15
Not much to the bracket. The fuse panel in my ‘94 has the screw holes that would hold it to said bracket and it’s just screwed through the bottom lip of the dash. As long as there’s enough slack in the wiring harness, there’s no reason you shouldn’t be able to add it to a truck without it.
ericbphoto
Overlander in development
16,706
Wellford, SC
3.0L
6"
Josh B
1,988
Oklahoma
I can't believe you'd rather do that than sit upside down in the seat looking up the firewall at the dashboard
ericbphoto
16,706
Wellford, SC
3.0L
6"
That's worse than waterboarding.
Junk Collector
Truck of Month
4,850
Rapid City SD
I think this was only an option for a year or two, IIRC I saw it more on 90 and 91’s than any other year. I have 92 & 94 Explorers that do not, my 94 Ranger does not, my old ‘89 Ranger did not. Pretty sure the last ‘91 Explorer I junked had one of those though.
RobbieD
2.9l Mafia
3,553
Georgia
The bean counters probably killed it.
DRanger024
Ham Radio Operator
487
Dale, WI
Solid Axle Swap 4x4
33x12.50-15
With that being said, I cleaned the broken glass and dirt off of the vin tag and this truck is actually a ‘90.
89RanBrII
33
Newcastle, Wyoming
Ranger & BrII
Ranger: 2.9; BroncoII: 4.0
My '89 ranger, my '89 BrII, and my sister's two 92 explorers have that style fuse box.
Edit: Her '91 has that style but her '92 does not.
SenorNoob
589
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Something to keep an eye out for in the junkyard. I've often wondered how you are supposed to change that flasher relay on the back of the fuse panel.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,738
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Suffer like the rest of us.
