What’s it this part?
Aaron285
Boynton Beach, FL
Started truck drove it. Still problem. Unplugged the tps while running and motor drops rpms for a sec and can back to normal idle. Drove home still problem. Going to pull codes with engine off first. Then engine on. With tps still unplugged.
Aaron285
Boynton Beach, FL
TPS disconnected. Engine off
63 63 115 36 3
Engine on
98 63 98 63 53
Aaron285
Boynton Beach, FL
TPS plugged back in motor off
Codes
1111 163 63
Motor on
3 17777
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,675
woodhaven mi
FORD mostly
BIGGER
sawzall?
Basically a noise filter
..the shiny cap critter.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I still don't understand what engine, ecu, and wiring you have. Sounds all mixed up from different years and quite possibly different engines.
What year is the engine, what year is the ecu, what year is the wiring harness and which match what? Things changed...
Aaron285
Boynton Beach, FL
Original truck 89' 2.9 manual supercab 4x4. The Motor and all harness's under the hood are off the same donor truck, which was 91 4.0 auto 2wd, The dash was out of a different 91 4.0 auto 2wd, and all other chassis electrical/lights are from the original truck/frame which is 89 2.9 manual 4x4. And the ECU/PCM is new/ refurbished from parts geek.com for a 91 4.0 manual 4x4.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,675
woodhaven mi
FORD mostly
BIGGER
sawzall?
I am still driving.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Can I call one of you guys????
Sure. I'll happily give you my number to take calls on 2.9l questions. Done it at least a dozen times now.
Aaron285
Boynton Beach, FL
I swapped from 2.9 to 4.0. But if you have any info or ideas on my current situation ill def call you.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Put the 2.9 back in it.
Problem solved.
My 4.0 is on the scrap pile. I pee on it. That's their value to me.
Well. They have parts that apply to 2.9, so not totally worthless.....
8,374
Here's the one question I may have missed
Did the engine run fine BEFORE and is this bogging a NEW thing?
Or is this part of final swap diagnostics?
I still can't see a 1991 4.0l PCM needing a MAP sensor????
Aaron285
Boynton Beach, FL
The 4.0 motor came out of a truck that was being scrapped, it had low compression in 2 cylinders and only idled. I got it free and sent it out to a machine shop to be machined and re built, motor, heads, everything, Only old parts on the motor are the parts with plugs, MAF, TPS, crank sensor, etc. The motor was installed in my 89 and has the engine harness, driver side and passenger main harness from the donor 91 ranger 4.0 auto 2wd. The ECU/PCM is refurbished from parts geek.com for a 91 4.0 manual 4x4. Motor starts, idles and revs up perfect, but when driving it Boggs around 2000-3000 RPM. 3rd gear seems to bog at 2000, 1 and 2 3000-3500.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,675
woodhaven mi
FORD mostly
BIGGER
sawzall?
Not map. Bap
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,675
woodhaven mi
FORD mostly
BIGGER
sawzall?
