What’s wrong with this piston
2.9._ranger
25
texas
ford ranger
All other pistons have a 2 etched in and this one is a little damaged and it can wiggle back n forth a tiny bit and none of the others can should I be concerned?
Junk Collector
Truck of Month
4,857
Rapid City SD
Did it run OK before you took it apart? How do the cylinder walls look? Post a pic of that if you can...
Looks like the engine ingested something at one point, a piece of metal would be my guess. Probably bounce around in there a while and dinged up the piston. If the cylinder walls look OK, and you have decent compression on that cylinder, don't worry about it.
2.9._ranger
25
texas
ford ranger
Cylinder walls look good and it ran good before I just wanted to ask and be sure
Junk Collector
Truck of Month
4,857
Rapid City SD
Not really ideal to find that but it happens. Looks like maybe a little nail or a screw or something, probably got dropped down the intake at some point.
superj
2,690
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
To be safe, you can get some fine sand paper and smooth those ding ridges so you arent creating hot spots in the combustion chamber.
But, i have had valves hit pistons and damage them way more and the engine ran like a top after the head was reworked and the piston ridges smoothed
