what can cause an oil leak at the top of a 3.0 vulcan?
4byRANGER
FORD
3.0 turbo
theres quite a bit of oil on either side of my 3.0 v6, fresh oil!!
i want to save my engine before anything worse happends, what do you guys think it could be?
4byRANGER
FORD
3.0 turbo
anything.. maybe cam postioning sensor!?
koda6966
61
The green part of NY.
2.9
Just to clarify this, it's at the top of the engine, not the top of the pan correct?
4byRANGER
FORD
3.0 turbo
yesssir!
i know i may have a main seal leak(but its small enough to not relate)
theres brand new 10w-40 running down either side of my engine, along the trans(but not on the trans) the dust sheild seems to keep it running along the engine
4byRANGER
FORD
3.0 turbo
koda6966
61
2.9
Well, I would try to clean it up the best you can, then watch it and see where it's coming from. Does it leak only when running or is it a 24/7 kind of leak? If you can find where it's coming from, it would be easier for you (and us) to diagnose the problem.
I used this method when I was JB welding my oil pan. I cut my leak in half by getting as many spots as I could.
4byRANGER
FORD
3.0 turbo
alright, would it be a good idea to use a foam engine cleaner then hose it off while the engine cool? or maybe pressure wash it?
koda6966
61
2.9
Hell, I just used soapy water.
fourwheelford
washington state
3.0 Flex
+1 on the valve cover leaking, maybe your pcv valve is plugged and the pressure is forcing oil past the gasket, that may also be whats causing your main seal leak. I had a volvo that did that and the pressure blew apart a bunch of vac lines and it ran like crap. Its a long shot but take i out and give it a shake, if it rattles its good if not replace it. That pressure will find a way out at the weakest point.
