ericbphoto
Overlander in development
- Feb 7, 2016
- 16,736
- Age
- 59
- Wellford, SC
- Ford Ranger
- Engine Type
- 3.0 V6
- Engine Size
- 3.0L
- 2WD / 4WD
- 4WD
- Total Lift
- 6"
- Tire Size
- 35"
- My credo
Soft tire causing enough differential speed to throw the ABS code? See if it resets after you fix the tire.Investigated the spindle bearing issue on the '90 and sure enough it's completely pooched, shaft seal had been leaking and that bearing hasn't behaved right for years apparently... not sure if the shaft is salvageable or not yet but I have a spare or two... need to order seals and bearing...
oh and on the wifes car apparently it has a nail in the tire, looked the other day and they all looked fine now one was flat, and she called and the ABS light is on so either there's a wheel bearing issue, sensor issue or the mouse got hungry... oh and the front alignment is bad or the tie rod ends are worn out, front tires are worn out on the outsides only...
