4.0blue98
I don't feel tardy...
705
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
I hear that they give you 4 brakes for redundancy, you really only need 2, even 1 if you like to live on the edge
That's right! Not to mention my ebrake works and you can downshift an automatic... I'm good for another 215k.
Neil Teske
42
Florida
Ford Ranger XLT
Finally repaired my armrest with the metal plate.
scotts90ranger
4,492
Dayton Oregon
2.3 Turbo
what does the torx nut do? does it like hold some transmission internals in place?
If memory serves it's part of the shift fork linkage for the 5/R slider, I'm pretty sure it's eccentric... I don't screw with that, even when rebuilding the transmission it doesn't need to be touched...
alwaysFlOoReD
5,139
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
After a long week with Dr appts, physical therapy, ongoing medical issues. Gave my ranger a good cleaning, after 3 months of solid rain, it really needed it. Drove to the lake for a bit after to take in some night air..also to enjoy the view.
Recently found a 5500 redline tachometer at the pull a part from a 94 2.3 5spd ranger.
When I put it a few days ago..it was way off, after some thought I removed the circuit board from 6cyl tachometer and installed it onto the current one.. works as it should. Perhaps people will stop thinking I have 4.0. Since my truck came with a 4.0 tachometer from ford..assembly line mistake. I like it more than the 5000 redline tachometer.
Some beautiful country where you are!
scotts90ranger
4,492
Dayton Oregon
2.3 Turbo
While it was warm and nice for the first time in a long time I mowed for a bit then dug into the '90's U joints... Took out the dry standard duty Spicer joints that I put in in like '10 or '11, apparently the factory grease just wasn't good enough :). One had spun the cap annoyingly but I had put full circlips on the outer joints (apparently just clearanced the inner joints so the partial clips could spin? whatever, that joint was dry too but no spun caps) so I took a shortcut and used red loctite, if I get a wild hare tomorrow I'll tack weld that cap to the shaft... I spent some time on the center slip spline, it was awful rusty for some reason, was pretty stuck in place when I separated it, gonna have to find a small wire brush to get in there then put some marine grease in there before reassembly...
Tomorrow I'll hopefully get the passenger side shaft back together with the wheel bearings and everything then I'll tweak the alignment back to where it should be and will likely weld something in place to hopefully keep the passenger alignment bushing from turning...
45
Wenatchee, WA
Ford Ranger XLT
31”
I figured it was something like that. Thanks
ElectraRider
107
Colorado Springs Co.
Ford ,Ford
2.9 ,4.0
loaded up the trash and hauled it to the dumpster at the shop.
ericbphoto
Overlander in development
16,744
Wellford, SC
6"
Who really needs 5th and reverse? Just remove that.
I use reverse. But with a 3.0l and 35” tires, 5th gear is just there so I can brag about having a 5 speed.
Bill
898
Sacramento, CA
Nothing yet. I need to wait for the coffee to kick in so I have enough energy to make pancakes and something else to eat. Then, I might take off one of the door panels to see if the 6.5" never used Boston Acoustic speakers I came across in the garage will fit in the front doors.
I think I bought them for a Mazda B2200 I had in the 90s and ended up installing something else.
CamTheHedgehog
ASE Certified Tech
399
Charlotte, NC
Ranger Edge
4.0 SOHC
Torsion Bar Max Crank (Pre-2008)
Professional Dingus At Work
Finally put my new stickers on- Both a reproduction Twin Cities Assembly decal and a fun “distance to the moon” one, both from Dave Barton over at prancingmoose.com. Great quality stickers, would absolutely recommend!
(I can’t get a good shot of the assembly plant one through my tint, but it’s there)
CamTheHedgehog
ASE Certified Tech
399
Charlotte, NC
Ranger Edge
4.0 SOHC
Went to the lake again today, spring like weather is really good to have sunshine. While my ranger was parked, had the engine idling for a bit, and a guy in a new super duty towing a huge boat pulled over for a moment and we starting talking about ford stuff. The way my ranger sounds he asked if I had a 302..others asked the same. I said no, mentioned what I had done for the engine and exhaust setup, he said good job and sounds good.
Had no idea the new 6.7 diesel has 500hp and 1200 of tq..that's impressive. I'm used to the ole 7.3 diesel.
Not to derail this thread, but out of curiosity, what have you done for the engine and exhaust? (My factory exhaust is looking a bit rough around the edges from the rust and I’m looking to upgrade)
ben_2_go
353
Third rock from sun
Furd
2.5 (4 Cylinder)
2.5 Scrap
235-75-R15
None at all.
Fiddy bucks local LKQ.
CamTheHedgehog
ASE Certified Tech
399
Charlotte, NC
Ranger Edge
4.0 SOHC
Like their pull your own part yards? I gotta check and see if they have one near me, I do go to pull-a-part quite often though
rusty ol ranger
2.9 Mafia-Don
7,700
Michigan
177 CID
Not the ranger but....
This load was stupid heavy. First load i hauled in 10 years of ownership of this truck i thought i mighta overdid it. But she got er did. The 460 didnt groan nearly as much as everything else
Disclaimer....i went 4 miles on no traveled dirt roads.
