The barrel of tools I got a couple weeks ago had someone's file based knife in it, dagger style blade with a 1/2" galvanized pipe handle where they ran out of ideas quick so it was electrical taped on... so I took the time with a diamond drill bit in the rotary tool to drill a pin hole, pressed the end of the handle flat, cut a couple small pieces of 1/8" steel for finger guards, peened the pin, welded the pieces on then sharpened the thing, will get a pic later... kinda useless but neat at the same time... a shop dagger might end up handy...
Then between rain storms I got the camper on the F350 so it's finally out of the shop. Now I gotta clean the floor, pull the '97 Ranger in for an oil change then get the wifes car in to check the cabin filter for mice, apparently it smells like a rodent invasion...
After that the '90 will end up in the shop to figure out the spindle bearing issue and fix the alignment issues...
