what direction to take?
black_demon69
142
AZ
4.0l
3 re curing codes (it does take a little time to set them again)
P0300 FORD - Random Misfire Detected
P0303 FORD - Cylinder 3 Misfire Detected
P0330 FORD - Knock Sensor 2 Circuit Bank 2
truck is a 2005 f250 with the 5.4l 242,000miles
symptoms:
CEL starts blinking and it starts missing and has loss of power @around 45 to 65 mph smooths out after that
CEL stops blinking a few seconds after gas pedal is released.
seems to idle fine
fuel pressure w new fuel filter as reported by scanner is around 40 to 45 psi
previous owner has replaced
spark plugs
coil packs
injectors
ECU
air filter
knock sensors
Yes he was throwing parts @ it and I don't know what kind of trouble shooting if any he did..
I plan on checking compression and possibly doing a cylinder hold test also smoking the intake to look for Vac leaks..
some guidance would be nice and appreciated
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Fuel pressure is too low, but I would check it with a guage not a scanner. Should be 65psi. Usually that would set a lean code but it's definitely somewhere to start.
If the knock sensor was replaced I'd verify the wiring and connection. But running lean can cause the knock sensor to throw a code (back to that low fuel pressure).
And running lean can cause misfires (low fuel pressure again).... so I'd be looking at the fuel pump or module.
black_demon69
142
AZ
4.0l
black_demon69
142
AZ
4.0l
Fuel pressure checked and is low I have ordered a fuel pump I will update when I get it in
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
Hope you bought a Ford pump.
black_demon69
142
AZ
4.0l
Carter pump
black_demon69
142
AZ
4.0l
Fuel pressure is better with new pump but symptoms are still the same and codes remain.
It was the original fuel pump and there were some metal shavings in the bottom of the fuel pump assembly
