- Sep 22, 2010
- 0
- Alaska
1989
- Mazda
- Engine Size
- 4.0 and 2.2
Ok, so first off ive been having some idling issues. I thought it was the IAC or MAF. So I cleaned both really good with MAF sensor (MAF Cleaner) and Carb and brake cleaner (IAC). Both didn't work. I then moved onto the coolant and engine temp sensors because my sensors weren't operating correctly. I thought it could be that because I thought the coolant sensor was sending the wrong message to the PCM.
I went through and tightened up all the fittings on the air intake and and checked the air filter. They all have seemed to help a little bit but the idle is still rough.
I did notice some moisture in the throttle body along with soote
Any thoughts?
Any thoughts?
