what drive shaft
Destroyer000
January 2009 STOTM Winner
MTOTM Winner
8
Plattsburgh, NY
1999
4.0. 4.0 Supercharged
specs dana 44 front 1345 transfer case . i need a dual cardan shaft for my front . did a 5.0 swap and my buddy had this tcase i could use. its all in but i dont have a front drive shaft. the stock shaft would be a perfect fit but the yoke on the tcase end is too wide . what shaft could i get from a yard that would bolt to the 1345 case? i dont have a problem welding up one thats how i got my rear one done. or does any one know of a site that would have a different yoke i could buy? winter is coming and i would really like to get a shaft figured out. i have a stock explorer rear i was going to cut and fit but my drive line angle is too steep for single ended joints.
Slammin Sam
4
Western Colorado
2.9
Most towns have a shop that does drive shaft fabrication. Local transmission shops should be able to give you a source. You mentioned that you fabricated your rear drive shaft. How did you balance it?
Destroyer000
MTOTM Winner
8
Plattsburgh, NY
1999
my shaft isnt balanced. its .003 out and actually smoother than my old set up. we dont have any shops in town worthy enough of tackling this.
