What engine for a Lotus7/ Ratrod?
fastpakr
2,842
Roanoke, VA
A 2.3 ecoboost would be a great option. I would assume it would be easy to find a used one in the junk yard with how common they are. could buy a whole copart mustang or just the engine and get a control pack from ford.
A Focus RS 2.3 in the Lotus chassis would be amazing.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,543
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Mazada 13b...
Robertmangrum.rm
Wannabe Overlander
1,636
Tennessee
2.3 EcoBoost
2.5 level kit with rear add a leaf appox. 1.5
305/70r17
Buy it, build it, and drive it like you stole it
Go crazy with it. How about an inline 6 like the 300 out of a old F100 then turbo it. Even dual carbs off the side would be pretty cool looking too. Those things were bulletproof haha.
racsan
4,497
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
escape 3.0 duratech.
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Uncle Gump
Token Old Guy
13,543
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Yes, I was gonna say this..
Only... multiple rotors.
We still have a 13b in a mid engine sand drag car. Nothing else on earth sounds like it.
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Definitely super unique. The perfect flavor of obnoxious.
ryan
Forum Administrator
Administrator
902
Wayne, PA
6.0
Solid Axle Swap 4x4
do you want to make power or having something unique?
if you want to make power, go with an LS
if you want to race and are concerned about weight i'd go with any number of turboed 4 cylinders
for something unique i might think about supercharged 3800
19Walt93
4,492
Canaan,NH
351
3"
235/55R16
A vendor at Carlisle was offering an aluminum cross flow head for 200 and 250 inline sixes that looked cool, sounded mean through dual exhaust, and was claimed to make good power. 200's were used through 1983, 250's through 1980. 250's all used the smallV8 bell housing pattern, 200's used a real small diameter bell until 81 when they made it bigger to have room for a C5's lockup convertor- I think a V8 bell housing could be tweaked to bolt up. 300's were great but they were also heavy.
Chapap
672
NW Florida
Ford Ranger XLT
2.3
1.5” till I get these springs replaced
225-70-R14
Straight six is probably the best for a show car... and they're cool. I'd probably lean toward a less computerized engine too. I6 is in the lead I think.
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
The ford Barra i6 would be a better choice than the 300 imo. Aussie ford equivalent of the 2jz-gte, for the most part.
85_Ranger4x4
17,953
SW Iowa
An aluminum block LS is lighter than a Ford 5.0 or the old SHO V6 motors, so I'm confused about the weight comparison above.
Either way - I wouldn't reach for a V8 on the Lotus regardless. Something small and light.
Truck engines are far the easiest to find and have iron blocks.
I agree with 4cyl Ecoboost. Wrecked Mustang and you have the whole kit.
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
The L33 (I believe) was a 5.3 truck motor and had an aluminum block.
Still.. way less common.
19Walt93
4,492
Canaan,NH
351
3"
235/55R16
In the early 60's Olds put turbo chargers on the aluminum 215 Buick V8, if you can find one it would be cool and different. GM gave up on trying to fix the oil leaks so they sold the design to Rover and they used it into the 2000's because it seems English cars are required by law to leak oil.
