stamina
- Nov 20, 2021
- Reaction score
- 34
- Location
- Wilmington, NC
- Make / Model
- Ford Ranger
- Engine Type
- 4.0 V6
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 4” suspension
- Tire Size
- 265/75/r16
- My credo
- built her in a storage unit
i have a 1990 ranger that i have gotten an adapter kit and saginaw power steering pump for, it’s almost installed but i have a stinging question, what fluid to use? everything w/ a steering gear by ford uses Type F atf, the saginaw pump from the 04’ liberty calls for just ATF (mercon or whatever) as it is a rack and pinion setup which fluid do you think i should use?
