what gear ratio
Boggin
48
awesome, thanks
90rangersuper
Pittsville,WI
im sure there will be more posts in this, if you can get a better pic of the axle that would help greatly
should of bought a ford:nono:
Boggin
48
i know :'(, im lookin for oneif i can get one
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
Jack up the back end of the truck, put it in neutral, and turn one of the wheels. Count how many times the driveshaft turns while you turn the wheel one complete revolution. If it's about 3.73 times, you have 3.73 gears, if it's about 4.10 times you have 4.10 gears, etc.
blackbronc
NorCal... no not Bakersfield.
89 BII retired
91 Xplodr Sport
They are Mazda axles not ford or nissan. Mark your driveshaft with some bright paint or the like right near the rear yoke. Jack up one rear wheel and mark it like the driveshaft. Turn the wheel exactly 2 full turns while you watch the driveshaft and count the number of times it turns. Almost 4 will be 3.90 a little over is 4.10. If your rear axle is welded then you will have to raise both wheels off the ground of course. and you would only turn the wheels 1 turn then. You don't have a d35 or 28 in the front either, it's an all aluminum Mazda independent.
blackbronc
89 BII retired
91 Xplodr Sport
1 turn of an axle will only turn the carrier 1/2 turn so you have to turn 1 axle 2 turns to turn the carrier 1. The exception is if your spiders are welded, you have a spool, locker or very good L/S. You would have to get both wheels in the air and turn 1 full turn in that case.
Boggin
48
Ive never really checked out the front susp. but i will take the laptop with me and go check your strategy
Boggin
48
ok, so i was just out there, i had to jack up 2 of the wheels, and i realized, when i turn the wheels the driveshaft dont move, yea i forgot all about my transmission was gone
Boggin
48
hold on..
i got to upload the pics
Boggin
48
shitty webcam pics
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Are your diffs welded up/locked or no?
If not, you have to do like blackbronc mentions (one tire of the axle off the ground, the other still on the ground). Turn the wheel off the ground exactly two complete revolutions, while counting the driveshaft (pinion yoke) rotations. As said, 3-3/4 turns is 3.73:1, just over 4 turns = 4.10:1, 4-1/3 turns = 4.30:1, etc.
Boggin
48
i tried, i had to lift up the 2 wheels, didnt you read all my posts?
and when i got two of them up, i can turn my wheels, If i turn one wheel forward, the wheel on the other side will go the opposite way, and when i do, the driveshaft dont move at all.. seems my trannys gone
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Which indicates an OPEN differential, which will just freewheel like that and not rotate the drive shaft. One tire has to be on the ground to keep it from spinning backwards. We do know what we are talking about here.
Boggin
48
we sure dont...but i cant spin my wheel when just one is on the ground,
and my tranny is gone anyways, so my drive shaft dont move nohow..
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
OK, now I got you, yeah the tranny is in gear or seized or (?).
You could unbolt the driveshaft from the axle flange and then check it (or maybe try it on the FRONT axle with the hubs locked, as both ratios have to be the same. Be sure the t-case is in 2WD.
Edit: Check that. If it's in 4WD, things won't turn.
