What Gears dose a stock ranger have?
BlueLighting1999
Des Monines,WA
What Gears dose a 1999 3.0L 4x4 have??
02RangerXLT
53
NE
bcost882
5
The Queens Country.....
3.0L, 1.6L
or look on the tag on your diff
3,614
Different trucks had different gears, need your axle code to tell you what you have.
BlueLighting1999
Des Monines,WA
Dam i used that Axle code page n the Tech section and i think i have 4.10's with a 8.8 Axle:yahoo:
R7 is the code
3,614
the code is usually two numbers, but R7 could be the code.
the axle tag is easier to use because it has the ratio right there on it.
02RangerXLT
53
NE
The door code is easier because you don't have to crawl under your truck! Yeah... R7 would be the 4.10 and 8.8, thats what I have lol.
Mac
183
C. Wisconsin
2000
199
Two numbers means open rear. With a letter in front, it's a L/S.
Dave
bmonee5
Oregon
damn i looked at mine at under axle it said 96. Then i looked at the tag on the rear and sure enough 3.73. I was convinced it was 4.10's but i was wrong.
Hopman
13
Manch-Vegas, NH
2.3L
Same here. Those 4.10's really help that 4-banger scoot.
