What gears to use?
AZFX4
Arizona
FORD
2.9
Ok so im in the middle of swapping a 4.0 into my 1990 B2 I will be using a stock auto tranny and stock transfer case. I will be running a full width dana 44 HP in the front and an 8.8 out back. I would like to run 35-37 inch tires. I am in need of new gears in both sets of axles. Any advice on the ratio? I was thinking at least 4.56 but a buddy of mine has a set of 5.39s for cheap any thoughts?
The Jester Race
68
Sacramento, Kalifornia
Ford, BMW
2.9, 4.0
I'm running 5.13s with 37"s. Your A4LD will hate 37"s with 4.56, and 35"s would be unbearable with 5.39s. But if you run 37"s or 38"s with the 5.39 you should be good to go.
-Jester
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
5.39 will be a little deep for 35s with a 4.0 but with an auto it won't be too bad. I'd certainly take 5.39s over 4.56s.
RavoHimself
8
enfield, ct
if you get 37's or 8's go with the 5.39's
if you get a 35 just stick with 4.88's or 5.13's(probably 5.13's because you have an auto)
Surrey
10
Vancouver, Canada
2.9
I would question how long that auto is going to hold up behind a 4.0... I would go with the gears you can get cheap. Unless it is a daily driver, the higher gears shouldn't really bother you.
The difference from 4.88 to 5.39 is only about 10%.
AZFX4
Arizona
FORD
2.9
Ok but it sounds like 4.56 is out? I would like to run 37s im just not sure how they are gonna fit with only a 3.5 lift spring.
The Jester Race
68
Ford, BMW
2.9, 4.0
Just fine if you're not afraid of a sawzall.
-Jester
BLOODBANE
19
Canon City, CO
FORDFORD
347, 4.oh
5:13's are as deep as the 8.8(unless its a FS 8.8)will take. I have 4:88's in my 4.0 Explorer with the 35's and its a little deeper than stock ratios. a buddy of mine(Thumper113) runs 37's/38's on his 94 Ranger and has the 5:13's and it does really well. I agree that with a tire that size, go as deep as possible.
AZFX4
Arizona
FORD
2.9
Yeah its a full size 8.8, And I have already done some work with the sawzall to clear 32s at stock height. So it sounds like I should be looking at 4.88s or 5.13s. It will be used as a daily driver on occasion so I would like to be able to run 60-65mph and get decent mileage.
The Jester Race
68
Ford, BMW
2.9, 4.0
Here's mine.
Running 5.13s with 37"s, I get just over 15 MPG city with a 2.9L. I cruise at 60 MPH at 3k in 5th gear, you should do better with the 4.0L.
-Jester
Surrey
10
Vancouver, Canada
2.9
5.39 to 5.13 is less than 5% diff. If they are available, and you want to run 37s might as go with what's cheap.
AZFX4
Arizona
FORD
2.9
That looks good jester! Thats about the height and stance im looking for. Although now that I have compared the price of 37s vs 35s im gonna have to take out a 2nd mortgage just to afford 37s. What size lift would you say that is Jester?
The Jester Race
68
Ford, BMW
2.9, 4.0
Thanks. I'm at about 8" of lift.
http://www.trailworthyfab.com/37-x12.50-R16.5-Military-Goodyear-Tire.html
They're no boggers but they're a fifth of the price(same tires I have). The don't work that well in the snow, but besides that they are great.
-Jester
59bisquik
April 2011 OTOTM Winner
Solid Axle Swap 4x4
Where do you find 5.39's for a D44/8.8 combo? The lowest I have seen is 5.13's.
FWIW, I have 4.88's and 35's with a A4LD. I would like to have 5.13's or deeper.
AZFX4
Arizona
FORD
2.9
justdifferentials.com has 5.39s for both axles. my 8.8 is from a full size bronco though not from an explorer.
