what is the general consensus on cylinder pressures?
swynx
9
lewiston idaho
Mazda
confirmed spark and fuel. did compression test with fuel relay unplugged, all spark plugs removed, and throttle all the way open. reason for the compression test is a no start condition.
i believe i remember that a low cylinder will cause a no start.
i got on the driver side
105/120/140/55 (80 wet)
passenger was
165/110/90(only when wet)/100
this one passenger cylinder that read 90, would bump up to 30 psi, and fall to zero.
obviously it needs a ring job.
i know that ive read you dont want a variance of more than 10%, but could not remember about a no start with compression results. i thought tho that anything under 90 and youll have issues.
8,374
Compression ratio will tell you expected compression test results
General rule of thumb is Compression ratio X 18
So 9.0:1 ratio would be 9 x 18 = 162psi
9.3 x 18 = 167psi
So what engine are you testing?
My 400k 4.0l OHV(9.0:1) runs 150-160 in all cylinders, 155 average
Compression heats up the gasoline to vaporize it enough so it can be ignited by a spark
Liquid gasoline won't ignite by spark, yes the "movies guys" take liberties, lol.
Vaporization much reach 30% for start up, and this is very dependent on outside temp, temp of the gasoline
120psi might be too low compression on a cold day, 90psi might be enough on a hot day
Ether(starting fluid) has a low vapor point which is why its used as a starting fluid for gas and diesel engine
Try Ether
If not firing with Ether then its a spark issue as well as compression, which is VERY low and all over the map, 165 to 55psi, thats not rings it valves
swynx
9
lewiston idaho
Mazda
its a chrysler 4.7 v8. stupid thing dropped a valve seat at 147k. i was in a hurry to fix it before i left for work so i neglected to check all the cylinders before i tore it apart, then when i got back i was in even more of a hurry, because its the wifes winter rig and winter is here. so i just checked the one cylinder i figured had dropped a valve seat. tore the head off put a new one on, now it wont start. ran fine before the valve seat dropped.
i quadruple checked the timing was right before i buttoned it back up. the passenger side head is the one that i replaced with a new unit. now it just wont fire up.
17,972
SW Iowa
Must be an epidemic on those things dropping valve seats.
Second one on here this week...
8,374
4.7l spec is 9.5:1 CR, but also saw 9.8:1, so expected is 170psi at sea level to 2,000ft
Only one cylinder is spec, 165psi, it should fire if spark occurs at the right time, this also means cam timing, at least on that bank is OK
But the others are leaking badly
You can do WET test on all and if they just go up a bit then rings are fine, heads will be the issue, if one goes up above 140 then its got bad rings
Also look at the PCV Valve and hose, if its full of oil then rings are on there way out as well
Oil vapor inside the crank case/valve covers is caused by Blow-by, the hot gases that "blow-by" the rings when a cylinder fires vaporizes the oil coating on cylinder walls and piston sides.
PCV system is there to suck this oil vapor out, and burn it in the engine
Normally its not all that much, cheap oil will vaporize more but still shouldn't be too bad
As rings wear out blow-by increases and so does the oil vapor it causes
rusty ol ranger
2.9 Mafia-Don
7,675
Michigan
177 CID
Are you *sure* you got the timing 100% correct?
Having that many cylinders that low on different banks really reads toward timing. The chances of it having that many valves screwed at once are pretty low.
Unless they got nailed by a piston.
swynx
9
lewiston idaho
Mazda
all 4 timing marks were lined up when i put it together. spun it over a few times, and the crank and idler lined up after like 4 spins. other than that they say that both cam gears "v8" symbol should point to 12 at the same time, and they did. there isnt much room in there for the timing to be off. they almost always smash the valve seat against the piston with the valve.
its super common, just takes over heating them once. which she overheated this one. thats when i found out this thing had been abused. instead of replacing the o ring on the thermostat they just put gasket maker. then when i tore it apart i found more gasket maker on outside surface of the oil pan/timing cover.
i guess ill pull off the valve covers and see what i can confirm for timing. maybe try starting fluid. possibly the jeep forums. for what its worth, the 4.7 sucks ass to work on. after i had pulled the whole thing apart, it definitely would have been easier to pull the engine out. there is a lot of dumb designs where you cant get 2 hands.
swynx
9
lewiston idaho
Mazda
got the valve covers off and first thing i noticed was that when comparing the new/old sprocket for the camshaft position sensors. they are different. none of the holes line up, and when i line up the new/old sprockets together, the mark i made on the oem sprocket doesnt line up with the mark i wouldve made on the oem cam. its about 90* off. i always mark my old stuff in random spots for a reference point
i knew that there was a jtec kit and a ngc kit. checked my order and i ordered a jtec kit.
im hoping that i can just swap my oem target wheel/sprocket on, and that everything else is the same.
swynx
9
lewiston idaho
Mazda
for what its worth, i swapped the sprockets out that controls the camshaft position sensor, and it fired right up. now its got a ping or knock at idle and only at idle, i assume its one of the hydraulic timing tensioners, so im going pull the cover off and remove the restrictor plate off one of the tensioners so it gets full oil pressure. see if that fixes it.
8,374
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Your a braver man than me. When I found the 4.7 I was working on spit a seat I said get it the hell out of my yard...
swynx
9
lewiston idaho
Mazda
if this was a customers vehicle, i most certainly would have. but its the wifes rig, and the main reason we bought it was for the winters around here (has limited slips front/rear and awd). winter is here, and ive done many many timing chain/ belt setups, figured it wouldnt be that bad.... it was. this is the worst vehicle that ive ever worked on. everything is in the most retarded spot.
i have a 5.3 and 4l80 at the inlaws that i pondered putting in, but decided against it. at this point i wonder if it might have been easier. because of random complications, i put the head on 2 times and did the timing 3 times, all in vehicle.
4.0blue98
I don't feel tardy...
704
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
I thought those restrictor plates increased pressure and decreased flow? I had a Jeep with a 3.7. Basically the same as the 4.7 minus 2 cylinders. Changed the tensioners when I did the headgaskets after an overheat. I think only the one tensioner had the plate. I had the oil coolant milkshake in mine and it ate a couple rod bearing shortly after. I swapped the crank and bearings then got rid of it. Felt good to have one less Chrysler product.
swynx
9
lewiston idaho
Mazda
now that you put it like that im not sure on the pressure/flow, all i know is that in the jeep community ive seen the tensioners make noise, untill you remove the restrictor plate. when i tore this 4.7 apart it did not have any restrictor plates.
this was my first chrysler product ive owned and aside from the limited slips front and rear, i hate the damn thing. its really comfortable on road trips, but everything is expensive for it, and a pain in the ass to work on. everything is in the way of something, thats in the way of everything else.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I've worked on my buddies 3.7 wrangler more times than I care to admit. Both the 3.7 and 4.7 are among the biggest piles of garbage ever produced and Chrysler just shoved the god awful disasters in everything for years with no other options. Overheat one to the slightest degree and your tearing it apart or throwing it in a crusher. Impossible to repair alot of basic stuff without pulling heads, intake, or other unnecessary items just to get to things. They burn oil, leak, rot, wiring is atrocious, computers fail hysterically frequency, crack, explode... I'd rather have a 2.9 then a 3.7 or 4.7.
