What is the true operating temperature of the 4.0?
Josh40601
MTOTM Winner
12
San Diego
So i am trying to find out what the actual normal temp is, what is "getting purty warm" and "Shut it the F off!!" temps are for the 4.0 in my Explorer.
With my Efans running, i usually run around 190*, with them off, i run around 205-210.
Hope you guys can help. Sorry if it is a double post. I searched through, and nothing popped up.
gw33gp
Ham Radio Operator
552
Costa Mesa, CA
4.0 SOHC
33"
Those temperatures are fine. If it hits 240 you should be concerned. Above that you may want to find out why it is getting so hot.
Josh40601
MTOTM Winner
12
San Diego
So 240 is cracking heads hot? or middle of the desert with the A/C on and the truck is getting warm?
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
My truck stays between 195-200 degrees. With any vehicle or liquid cooled motor I would be keeping a close eye on the gauge at 225 degrees and I'd be turning the ignition off at 240 degrees. If it happened twice I would start looking into a problem within my cooling system.
bobbywalter
Ugly Truck of Month
TRS 25th Anniversary
4,703
woodhaven mi
FORD mostly
BIGGER
sawzall?
depends on gauge and location.
200-225:icon_thumby:
bobbywalter
Ugly Truck of Month
4,703
woodhaven mi
FORD mostly
BIGGER
sawzall?
cracking heads hot is already lost too much water and why i am hot hot....
slow slow leaks that creep up and kill....
Josh40601
MTOTM Winner
12
San Diego
thanks gents. So i will kick the aux fans on around 215-220.
