What is this called and what are they made of?
rngrracing96
55
NH
2.9 EFI
33x10.5x15
Its a very simple piece seen on trophy trucks a lot. Its the black plastic/rubber/fiberglass guard under the bumper, but I have no clue what its called. The reason I ask is because I am hoping to make a bumper almost identical to this one (see picture below) with that lower black piece. I think it looks BA on that BII. Hoping to figure out what matterial it is. Thanks!
Dune Runner
Alpine, Ca
I forget what the material is called. We have a roll of it where I work. I will see if I can find out the name of it. It's kind of a plastic that feels like rubber. Real tough stuff. I have seen it used on builds many times. I also like the look.
Dune Runner
Alpine, Ca
High Density Polyethylene (HDPE) Sheeting. Found it. You can buy it on ebay or source it online. They even sell it in different colors. Glossy or flat. Google is your friend.
rngrracing96
55
NH
2.9 EFI
33x10.5x15
Awesome! Thanks for the quick response!
rngrracing96
55
NH
2.9 EFI
33x10.5x15
Also where is a good place to get those fasteners? are they just quarter turns?
Dune Runner
Alpine, Ca
They look like counter sunk bolts into beveled washers.
desertruck
The piece is called a valance and you can get the washers from kartek they are called body washers under the body panels tab on kartek.com they have aluminum and polyurethane ones...that valance is likely abs plastic and is pretty stiff I suggest the aluminum body washers
rngrracing96
55
NH
2.9 EFI
33x10.5x15
Thanks! huge help
Dune Runner
Alpine, Ca
Try McMaster Carr
