If the hose is disconnecting from the PCs valve, a small hose clamp should work. If the POV valve keeps popping out of the valve cover, etc may help or you may need a new grommet to hold it tighter. May also want to try a new PCs valve. If it’s stuck closed, Maybe crankcase I pressure is pushing it out.
