What part is this small shock absorber.
tekkatekka
5
ford ranger
1991 Ranger 4x4, 4.0 engine. On the drivers side below the power steering pump and toward the frame there is a small shock that mounts to a bracket attached to the engine. This is probably the original part. What does it do and how critical is it to replace?
ericbphoto
Overlander in development
16,743
Wellford, SC
3.0L
6"
Engine vibration dampener
alwaysFlOoReD
5,135
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Toss it if you want.
RobbieD
2.9l Mafia
3,570
Georgia
It's not necessary, but it did take some stress off of the motor and transmission mounts. If you do remove it, then it'd be a good idea to occasionally check that the motor and transmission mounts are unbroken (especially if you beat on the truck a lot).
19Walt93
4,500
Canaan,NH
351
3"
235/55R16
It's not to protect the mounts, it's an engineer soaking up the vibration from a poorly balanced engine rather than actually fixing the problem. I'm sure accounting was ecstatic because it was cheap.
