What the best priced suspention lift? 4" to 6"
Redneck Cowgirl
I want a lift for my 07 Ranger... and am having a hard time finding a lift that does not cost a arm and a leg:confused: What you all know???
Todd
HCT
12
Troll land
BIITR
Solid Axle Swap 4x4
Seeing as you have an 07 that has SLA front susp all the kits are going to be $$$$
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Any 4WD shop will have them (or you can order from numerous places online).
The Superlift kit is probably the lowest-priced kit that's decent for your '07.
If $$$ is an important concern, I would look at doing a bodylift on it.
Suspension lifts don't do a whole lot to improve the wheel travel and performance on the SLA truck, they almost literally just fit the description of "lift kit".
A bodylift is about $150 and will still allow you to fit a set of 33x12.50" tires on it just the same.
Redneck Cowgirl
Yaa I know that.. but I am looking for more a trail truck, I live 2 hours in the bush on loggin roads.... And I might put Baja fenders on her anyways gives me 3.5 inches extra clearance
Ozwynn
200
Berrien Springs, MI
RE Interceptor
If you can't go through it or around it, then go over it.
try camburg engineering. it will be expensive but worth the price for the long travel kit.
Todd
HCT
12
Troll land
BIITR
Solid Axle Swap 4x4
For anyone that wants a wheelin rig of a newer SLA truck I think an SAS is the way to go. Spend maybe a little and get way more.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
krugford
Iowa
I've looked the camburg site to drool, but I think if I was gonna spend that much, I would build my own.....
brendank
It's only money...
Forum Staff - Retired
Saskatoon, Saskatchewan
Yup, lifting or modifying your current system is a dead-end path. Throw in a solid axle and you won't regret putting in the extra effort.
JohnnyO
Moderator Emeritus
2,855
Pittsburgh, PA
2.3 EcoBoost
1.5"
The Camburg kit is only for 2wd Rangers.
If it's just a matter of logging roads, a bodylift and 33" tires would be fine.
Cowgirl, for your needs I think a Superlift kit and 33" tires would work well for the money if you want a suspension lift. A bodylift doesn't get the frame any higher off the ground except what you gain from taller tires.
That said, you can get taller and longer travel kits from
www.racecardynamics.com
and
www.dixonbrosracing.com
