What transmission ?
lilbdfrd
Wilcox,NE
Ford Bronco ii
So I have a 84 bronco ii with a 2.8 and a 4-speed ! Do I have a tk4 transmission ? I’m in need of a shift really bad old one broke and now I’m stuck in reverse !
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
lilbdfrd
Wilcox,NE
Ford Bronco ii
Would you know where I can find a shifter?????
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
Ive only seen 1 aftermarket one for the TK5, no idea if itll work on a TK4.
Says its out of stock and only for a TK5.
Could try www.car-part.com
lilbdfrd
Wilcox,NE
Ford Bronco ii
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
you can make a lil collet ring and ball out of delrin or nylon cutting board to get by. the tk4-5 should have same shifter.
if you pop it off you should be able to stabilize it in the pocket to change gears and move it.
